Old 01-30-2014, 01:26 AM
maxhifi's Avatar
maxhifi maxhifi is offline
Update: filter capacitors seem to be fine, no characteristic hum, and b+ on all three sections is over 110v. On AM the radio plays like new, on fm the volume is much quieter, and when you turn it up the sound is distorted, although it does pick up a lot of stations. The AGC voltage is only 0.6v with the strongest fm station. There are no paper or oil capacitors in the radio circuit only audio, and it works fine on am so I assume they are good.
All tubes original and if transformers still have undisturbed drops of white paint on alignment screws... Got to be something wrong in the fm section which isn't obvious to my amateur radio repair skills
All tubes test good on eico 667 including for h/k leakage
