Even if they knew there was any kind of battery in the set, most people would not have the faintest idea what it is there for, let alone how to replace it. When the battery in these Magnavox, et al. TVs finally failed, erasing all channel programming, I imagine most people just left it alone, changing the channels manually using the keypad on the remote. There is also the possibility of the dead battery leaking in its holder inside the set, but again most set owners didn't know or care about it. (I wonder how many of these Magnavox Star System and other TVs have been found with defective backup cells that have leaked and corroded the contacts of the holder, when the set is being repaired due to some other problem. ) The same thing can and probably does happen all the time with today's flat panel TVs, which I'm sure also use backup batteries for channel memory and backup of other settings, although many FPs quit and are junked long before said battery fails. Remember, most non-technical people know only three things about their TVs: how to turn it on or off, how to adjust or mute the volume, and how to change the channels, once the set is installed and set up. They couldn't care less about backup batteries or anything else inside the television, so long as the set works properly.
