I don't know what to say about this. The second picture looks like the kind of ringing you might get from a tube-pickup camera at high gain, but you say these are all CCDs, correct?
The tinted whites could be due to the different color paths saturating at different levels, but generally I think one would expect the red to saturate first in a CCD, making the highlights turn cyan or blue. so, I am at a loss to explain that too. Maybe there are white clipping adjustments somewhere? |
I used to work on lots of these.
you need to replace all of the Mini capacitors all over, then the Encoder board will have to aligned, the red problem also sound like bad cap in the red white Clip circuit, most times you can replce the capacitors and it will looks fine without alignments, unless you want to match 2 cameras the same |
