Old 12-21-2013, 07:24 PM
47'Plymouth 47'Plymouth is offline
Smile Need a good isolation Transformer
I'm in need of a isoliation transformer for safety on my bench
ACDC RADIO AND SERIES STRING TV REPAIR
I VE GOT A PACEMAKER/Diffulator to protect as well as me
From a shock hazard
Jody
Old 12-23-2013, 01:05 AM
Gunslinger Gunslinger is offline
I have a couple. Will get model number on Monday and will post it with price.
Old 12-23-2013, 02:33 PM
Smile
Great that you have those trannys
Just wanted to protect myself and my medical device
Thanks Jody call me ASAP (864)923-5733
Old 12-23-2013, 03:21 PM
I have a RCA WP-25a for 40.00 plus shipping
I have a RCA Wp-27A for 65.00 plus shipping. I also have a Sencore PR-57 $125.00 plus shipping
The RCA Wp-25A needs on receptable to be replaced. I just taped it off and never needed to use that one tap
Old 12-23-2013, 05:02 PM
davet753's Avatar
davet753 davet753 is offline
David Thomas
I used to have one of the Sencore PR57's, and it was (next to my VTVM), the most used piece of test equipment I owned. The PR57 is a great product!
Old 12-23-2013, 05:16 PM
PR 57 may be sold.
Old 12-24-2013, 08:08 AM
PR57 only weak spot is the outlets. otherwise a great machine.
Still have the B&K equivelent, flawless for many years.
Old 01-18-2014, 06:24 AM
VTVM VTVM is offline
Can you buy them new, too? I need one.
Old 01-18-2014, 07:24 PM
still have a Pr57. Receptable is fine.
Old 01-18-2014, 10:14 PM
I'll PM
Old 01-18-2014, 10:16 PM
Old 03-31-2014, 04:37 PM
K7sparky K7sparky is offline
If you have a scrap yard around and don't mind building your own case you can use control power transformers out of old switch boards.
Most scrap yards are HAPPY to get rid of transformers as it is a pain to burn the insulation to strip the copper from the core.
Almost all switchboard transformers have a KVA rating on the voltage plate. A 440 / 220 primary hooked 220 with a 120 / 220 secondary hooked 220. Operate at 120 / 120. You will be limited to 1/2 the KVA rating for current on 120 because of wire size. Heavy, but cheap. If you have a 220 outlet then the 220 / 120 gives you full current.
Old 04-02-2014, 09:07 AM
One just showed up on ebay:
http://www.ebay.com/itm/Vintage-RCA-...#ht_302wt_1068
Old 04-03-2014, 09:57 AM
From a shock hazard
Jody
Being an electrician first and then a electronic technician second, I cant stress enough, the importance of a GFCI receptacle.
Even if the receptacle you're using isn't grounded, it will still give a degree of protection.
Besides a GFI, I still use an isolation transformer, for testing and some servicing.
