Old 06-22-2013, 07:56 PM
jg6364 jg6364 is offline
Zenith System 3
Originally Posted by pac.attack76 View Post
Same cabinet huh? looks great. Yeah, i'll get this one running eventually and rework the cabinet. Still have the remote that uses the j battery.
Your set looks like it has hinges at the speakers. Maybe I am seeing things but does that open?
I wish you could post a pic of the remote. Hopefully I can find one like it. I got a remote the other day that had the "space phone" button but after I got it I found that it was an ultra-sonic remote instead of infra-red. Oh well, I can add it to the collection.
Old 07-02-2013, 06:06 PM
Originally Posted by rpm1200 View Post
Anyone remember the Recoton F.R.E.D.? It was a third-party stereo decoder box for TVs. It came out in the mid-80s. It could be fed from the MPX out jack (Stereo Ready!) where available, and it also had a suction cup pickup for TVs without the jack.
I bought the stereo decoder for my philco console tv back in 86 it worked great.
Old 07-02-2013, 06:35 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
An ultrasonic Space Command remote with Space Phone? I had never heard of such a thing, must be a very early model.
Any kid with a toy xylophone anywhere near one of the sets that remote goes with could end up inadvertently calling Japan.
Old 07-02-2013, 10:09 PM
zenith2134's Avatar
Yes, there was an ultrasonic Space Command system-3 Zenith with Space Phone. 1979ish. Mine had Zoom as well, which applied a boost voltage of 500-700Volts via a relay on a daughterboard.
Old 12-21-2013, 02:00 AM
pac.attack76's Avatar
Stuck in the past
Just got my new Fluke meter. where should i begin testing on this set as far ad components go to track down the failure based on what was mentioned above?
Old 12-21-2013, 03:44 PM
Unfortunately I dont have a manual for it. Lets narrow things
down & maybe someone can help.
Do you get OSD ?
When you try off air do you get snow or a blank raster or
no raster at all ?
Have you tried running something like a DVD through the
RCA jack inputs ?
BTW you are gonna love that Fluke, nothing like working with
a quality meter.
Old 12-21-2013, 10:28 PM
Stuck in the past
I haven't tried it lately but last time, all i got was a click of a relay when turned on. changing channels causes a brief pop in the speakers. no static, no pic or anything. the gun doesn't appear to be lit either. no change from dvd players etc.
Old 12-22-2013, 12:10 AM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Anyone got a pic of the needed remote? Junked a few zeniths awhile back, remember the remote using that weird battery.. May still have the remotes...
SR
Old 12-22-2013, 08:34 AM
OK you got to get the HV going. Almost everything runs
off it inc the CRT filament. Most had a strange start up
design. You may need more than a meter on this one.
Start with the hoz output transistor ( HOT )& see if its shorted.
If not see if you get 120-150 VDC on HOT collector, use the
metal on the HV board as ground.
If there is a small board on the HV board assy see if a
resistor burned IIRC a 2 K 1W. If burned there is more wrong.
Old 12-22-2013, 01:54 PM
Stuck in the past
Will check and let you know.
Old 12-22-2013, 03:12 PM
Stuck in the past
Will this need to be plugged in and turned on or just plugged in. not seeing a burned resistor on the small board.
Old 12-22-2013, 04:46 PM
holmesuser01's Avatar
Sears sold a ton of these sets when I worked there. I never did anything more on them than replace the whole module and do a quick set-up on them.
Any idea which module (s) your set uses? It's on a sticker somewhere, and written on the module, too, probably.
Bruce
Old 12-22-2013, 06:03 PM
Stuck in the past
Label on the insife of the cabinet shows high voltage horizontal sweep module as 9-454. If that's not it, let me know.
Old 12-22-2013, 08:51 PM
I'll look and see what I have tomorrow. (It's dark here.)
Bruce
Old 12-22-2013, 09:56 PM
W3XWT W3XWT is offline
3 Phase 480VAC is QRP
As We Remember F.R.E.D.
ARF!
I remember seeing a bunch of those things being peddled at the 1988 Texas Show for next to nothing! If I'd had room in my suitcase I would've brought back a few. As it was, my parents "gifted" me with one for my birthday. They found it at the Andrews AFB BX. It was the "high-end" version with a lot of useless bells and whistles.
As for the "pickup" it worked in a fashion... But, unless the broadcast signal was perfect, it was noisy as hell.
I still have the box somewhere in my laundry room as I've not used it since buying the house in 1995...
Reception Reports for Channel 37 TVDX Can Not Only Get You a QSL Card, but a One-Way Trip to the Planet Davanna is a Real Possibility...
