Welcome to vintage TV restoration!
Sounds like a very interesting find. Post some pictures when you can. Yes you should have 60Hz sawtooth in the vertical. Could be that the vertical oscillator isn't running or a problem in the output stage. Without a schematic, it will be a bit more challenging. You will probably find the problem is a bad paper or electrolytic capacitor. It is usually best to replace all of these troublesome caps, typically called a re-cap. Good luck and keep us posted. |
