Old 11-27-2013, 03:29 PM
Did your supply voltages ever come down closer to spec? What DC voltage do you read now on pins 4-6 of V13B(horz osc)?
Old 11-27-2013, 03:57 PM
And if the voltages are *still* too high, perhaps use your variac to reduce until they are normal and see how the horiz behaves.
Is 10 k resistor from horiz hold to the transformer ok? How about the 50 uuf cap to the sync circuit? Does the "parts set" have a good horizontal transformer if you need it?
Old 11-27-2013, 07:43 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Tried it on the variac, and the only thing that happened is that the picture shrunk, and it shrunk as it was, it didn't come into sync.
I'll check the 10K resistor next. Everything on the parts set (except for the frozen controls) *looks* okay? But I haven't tested anything.
Old 11-27-2013, 08:53 PM
Darn... that actually worked on my 7" Philco... thing made a decent but small picture at about 90 volts line... I found some parts way out of spec!
12K does not seem to be too far off, does the pot have it's full range of 20K?
Old 11-27-2013, 07:41 PM
Kamakiri's Avatar
-69 VDC on pin 4, 2.44 VDC on pin 6. Still high.
