Old 11-05-2013, 09:28 PM
Bobby Dip Bobby Dip is offline
Where to get picture tubes?
I'm normally an antique radio guy, but I picked up an early 50's experimental car TV from what used to be Delco Radio. This is a one-of-a-kind set with no documentation, and is missing the picture tube. I would like to restore it to working condition, but there is no point going any farther until I procure a picture tube. There is no cabinet (some GM concept car was the cabinet!), but it looks like it must have taken an 8" round tube. I think the most likely candidate is a 8AP4. So where do you find these? No luck so far on eBay.
Bob D.
Old 11-05-2013, 09:42 PM
The 8AP4 is going to be hard to find I think.
There is a complete Arvin TV on eBay right now with one in it, kind of an expensive way to get a tube.
http://www.ebay.com/itm/Arvin-4080T-...item2ecb8d801e
Old 11-05-2013, 11:35 PM
I still think it looks like a 10BP4 would fit; I'd have to try one, since they are pretty easy to find.
Old 11-06-2013, 06:54 AM
wiseguy wiseguy is offline
I think it uses a 15GP22
Old 11-06-2013, 09:47 AM
earlyfilm's Avatar
Eternal Member
Bob,
I assume that this is the set pictured on ETF:
http://www.earlytelevision.org/delco_car_tv.html
For a CRT, I'd buy one of the inexpensive universal test CRT's and use that until you get the thing working. I suspect that the set used a round glass 7 inch magnetic deflection tube, not the 8AP4 which was a metal bell CRT. The style of mounting bracket is rarely used for metal tubes.
First, I question it being made for a car.
I suspect that it was intended to be used as a field survey monitor and mounted inside the back end of a small panel truck and it could be used in remote areas where there was no AC available.
There appears to be a nameplate on the chassis. What does it say?
You also seem to be missing the complete power supply, which probably would be mounted on a different chassis. Unless you can find more information about the set, you probably will have to reverse engineer the set to build a power supply.
Test CRT's are discussed on:
http://videokarma.org/showthread.php?t=252335
You can find additional tube data here:
http://tubedata.tigahost.com/tubedat...37/5/5AXP4.pdf
http://tubedata.tigahost.com/tubedat...168/8/8XP4.pdf
James.
Last edited by earlyfilm; 11-06-2013 at 12:33 PM. Reason: Added links for Test CRT's
Old 11-06-2013, 10:49 AM
Bob D.
The tuner and some of the components are too new to be early 50's.
It's more like 1956 or newer. The yoke is a narrow deflection angle type.
I doubt they used a 7GP4 or an 8AP4, as they weren't that available, even then. The 10BP4, always seemed to be available, way into the late 60's.
Old 11-06-2013, 12:08 PM
Someone mentioned that it has a metal CRT style anode connector - Considering that this set could very well have still been in the developmental stages, it stands to reason that they may have been using a conbobulation of new and obsolete parts.
Old 11-06-2013, 01:16 PM
I cringed when I saw in the item description that the Arvin TV mentioned in this thread can be used with a Comcast (!) analog cable box. I mention this because I've read some rather disparaging comments in this forum regarding Comcast and its cable service, referring to the company as "Crapcast". Thank God I have Time Warner cable here. Not one bit of trouble with the service, although I do not use a cable box. The cable connects directly to the TV, so there is nothing much to go wrong at my end except problems with the physical cable line coming into my apartment, the cable going to the television, or the splitter that divides my cable signal between the TV, my computer, and my telephone (all three use the same cable, thus the need for a splitter).
Old 11-06-2013, 01:51 PM
A friend gave me a 10BP4 to try. The neck fits in the yoke, but it is too big-a-round for the front support. Even if I modified the front support, the 10BP4 would stick out way beyond the controls and make them inaccessible.
I might be willing to buy a complete set to obtain a 8AP4, if the price is right. What sets use an 8AP4?
Bob D.
Old 11-06-2013, 02:23 PM
Bob D.
The Arvin linked in the second post is about the only one and it is rarely found... there may also be some "house brands" that are actually the same set. Metal cone CRTs are also more likely to be "gassy" than all glass CRTs.
Take a good look at the pictures in the eBay link to the Arvin set... it clearly shows the metal cone of the CRT and the plastic insulator around the front of the tube to allow the metal cone to be connected to the HV supply.
It would be a shame (and expensive as well) to have to swipe the tube out of a clean working Arvin, but these don't turn up very often.
Old 11-06-2013, 02:42 PM
Bob D.
I guess I stand corrected!
Evidently, they did use a 8AP4! After I looked at the entry at Early Television website, that specified an anode connector for a metal cone CRT.
I've seen many early TV sets, but didn't know an 8" metal cone CRT existed.
The only metal cabinet Arvins and Silvertones, I saw were 12" models.
Old 11-06-2013, 03:08 PM
John Marinello's Avatar
<-- "Byron"
That's Don's TV. There's a chance he has a spare 8AP4, so ask him if he would
sell one.
Old 11-06-2013, 04:03 PM
earlyfilm's Avatar
Eternal Member
Bob D.
Bob,
I'd like to know how you determined this was an 8AP4.
That is one of the last CRT's I would have guessed.
If you look at the Arvin pictures you will see what a metal CRT anode collector looks like. Metal CRT's are prone to leakage with extreme temperature shifts like one would find in a car with the changing seasons.
Your picture on ETF showing the anode, looks to me like a universal anode post (like Dumont used) or cavity (like most others used) connector, that has the cavity part missing. (It has been 50+ years since I looked at one of these, but the two parts were usually held together with a screw.) In the late 1940's they were available as universal replacement parts, because some CRT's especially scopes, came with either gender connector.
It would help if you could post a larger image of the connector. Also, of the backside where the power comes in to this set. I do not see any thing that looks like a vibrator or a dynamotor and in the 1940's & early 1950's nothing else could generate HV from low voltage DC until the power transister came out.
I assume that you know that the metal anode will run at about 7,000 volts and requires an insulator between it and the metal chassis.
The bottom of the CRT strap looks to me like a strap for a glass CRT that is missing the felt or rubber pads.
Until you can prove the set is complete enough to restore, I'd still recommend that you stick to the inexpensive test tube.
James.
Old 11-06-2013, 10:47 PM
Thanks for all the excellent advice. You're right, I don't know for sure that it takes an 8AP4. (Maybe it's a 7".) But I do know that a 10" won't fit, I tried one. I like the idea of using a Test CRT. I will try to find one.
You're also right that the set has no power supply. Evidently, this was on a separate chassis (probably using a vibrator). The set has a rather large gauge wire for 12V power that feeds the filaments. There is a connector for the remote power supply with 12V out and a single B+ line in. The B+ input goes directly to a filter cap rated at 300V, so I know B+ is less than or equal to 300V. I figure I'll be able to make a good guess at the B+ voltage after looking up a few of the tubes in my RCA manual. I have a Heathkit adjustable HV power supply to experiment with before I build a dedicated supply.
This project is going to be a real challenge with no documentation, and no guarantee that this set even worked when put into storage. (Also I don't have much experience with TVs, antique or otherwise.)
A fellow poster put some pictures of this set on Early Television Museum. I have also posted to Antique Radio.
http://antiqueradios.com/forums/view...p?f=3&t=234225
Bob D.
Old 11-07-2013, 12:12 AM
The only 7" CRT I can think of is the 7DP4 and that was only used in the 1946 621TS as far as I know, it was also electrostatically focused so the Focus magnet wouldn't work with it.
The 8" Rectangular tubes of the mid 50's (8DP4) has a very short bell, your set obviously had a tube with a long bell. The 8AP4 is looking like the most likely suspect, out of date by the mid 50s but it would have still been readily available at that time.
It would be nice if you could get your hands on one (even a dud) and see if it fits.
