It appears to be item K7 on the Sam schematic which is actually a capacitor and a resistor in one package.
The cap is 5000Pf but I'm not sure about the resistor, if it's .2 Meg than that would b 200,000k. Sams lists a couple different aftermarket part numbers, someone might have on of them laying around. otherwise you'll have to make one from individual parts. This cap would probably work:http://www.mouser.com/ProductDetail/...p7xmDnliurA%3d |
The other Q is how many volts to use for cap. Do 2 KV
to play it safe. Damned if I know what its for without the rest of the schematic but it looks like isolation for safty. 73 Zeno
"I know it's true, oh so true, 'cause I saw it on TV"—John Fogerty |
Looking at the schematic, a 1/2 watt would be fine. Most hot chassis isolation resistors that I've seen generally were 1/2 watter's. There's not any current (except maybe from your body to ground) but mainly used as a safety component to minimize any floating potential.
A polarized plug or noting which blade is the hot would be good too. |
