Old 08-28-2013, 09:37 PM
sampson159's Avatar
sampson159
clean as a pin!
Old 08-29-2013, 08:16 AM
Originally Posted by sampson159 View Post
clean as a pin!
The term is usually "Neat as a pin". Real Estate jargon.
Just how neat or clean is a pin?
Old 08-29-2013, 08:51 AM
VintagePC's Avatar
Tube bug got me 05/2010
Really depends how well you washed it after giving that last craigslist fishtanker a million pinpricks as punishment...?
Old 08-29-2013, 11:29 AM
kx250rider's Avatar
REAL TVs have TUBES!
WOW, that's CLEAN!!!!! Nice find, and I think it's in the best shape I've ever seen a small B&W plastic portable in.... ever!
Charles
Old 08-29-2013, 11:44 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Originally Posted by Robb View Post
Let's get together next time you come to Buffalo. I'll send you home with some nice additions to that collection
Old 08-29-2013, 12:59 PM
Robb's Avatar
Robb Robb is offline
Find me a mint Porta Color set and I will come right away !
flickr
Old 08-29-2013, 01:01 PM
Kamakiri's Avatar
Well, just have one shipped here, then come get it! There's enough of them for sale here and on ebay....just not up North
Robb's Avatar
Charles
My other B&W Are mintier.
There's a lil Magnavox here that is flawless.
http://www.stevemeadedesigns.com/boa...table-crt-tvs/
You guys are always searching for them on ebay. I dont have patience to search ebay consistently !
flickr
Old 08-29-2013, 01:40 PM
Picked up this Rare Sharp 2U-121C Black and White Vacuum Tube TV for free, untested. Gave it a cleaning, polishing. It is in real nice condition, no cracks or faults on the case.Turned it on waited 45 seconds and it works. I believe this was made in 1971-72 ?? Made in Japan.
I cant find any info on it. I peeked inside and noticed it is a tube hybrid set ?
Some pics and video
http://youtu.be/kL_Bmrzoc_s
How do you know the set "works"? Your Youtube video shows the set getting nothing at all on any channel except snow.
BTW, in the '70s I had a Sharp 12" portable, model TU-40PA, but with the controls mounted horizontally above the CRT, a monopole VHF antenna, and an earphone jack. Worked well at first, and I enjoyed watching it, but after a couple years the VHF tuner developed a problem (a poor connection, I suspect), although after 40 years I don't remember anymore; I could get the set to make a picture by wedging a screwdriver between the tuner shaft and the cabinet, but later the TV developed another problem (don't remember what) and I finally wound up junking it. I would think that TV would have lasted at least five or perhaps ten years with only an occasional tube replacement, if that. That set was built in the NTSC era and, supposedly, was made to last, so I would have expected it to work at least through the '70s and perhaps most of the '80s. However, with most of the set on a PC board, it might have developed serious problems anyway after a short time due to the horizontal output and other high-power tubes (such as the audio output tube) generating so much heat. I lost a CTC-12 RCA clone color TV in the early '70s when the video output board cracked, probably due to high heat inside the set and other factors (such as the materials early PC boards were made of, which I suspect was phenolic that doesn't stand up well to high temperatures).
Old 08-29-2013, 04:48 PM
Robb's Avatar
Because if set turns on ans shows snow, it works.
flickr
Old 08-30-2013, 08:15 PM
electroking's Avatar
a- v- karma member
How about connecting it to a source (VCR/DVD player with modulator output
set to channel 3 or 4) and looking at a real picture?
Old 08-30-2013, 08:37 PM
Robb's Avatar
Not really on my high priority list right now.
flickr
Old 09-02-2013, 08:25 PM
Robb is correct. I used to tell Jr. techs about "good snow" &
"bad snow". You can tell a lot by how the snow looks. Streaky or
weak snow is bad. Lack of snow is worse. Nice sharp snow & a
nice waterfall in the audio is a beautiful thing. If you have a
good snow picture you will almost always get a very nice picture.
You may get a snowy pix but a new RF amp or mixer/osc will
take care of that. Kind of strange since most of the snow is
noise that is generated inside the TV............
Old 09-03-2013, 07:40 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Sets with more I.F. stages will produce more snow. I have noticed that 1940s sets, especially the lower end models will even when working correctly not produce much if any snow on unoccupied channels.
Old 09-03-2013, 01:59 PM
My first Boss, in explaining replaced parts to a customer, would refer to the RF amp as the "de-snower" tube.
