Old 08-26-2013, 07:04 PM
Old TVs are better!
Generally I focus it right on, however if the vertical is stretched, the raster trace lines will really be noticeable. If your playing a DVD or watching broadcast with a digital converter box, where the picture is in the 16:9 format it might be that your trying to make the picture fill the screen by turning up the vertical height, stretching the raster way too tall.
Nearly all standard def TVs, will show trace lines when you look at the screen closely. Guess they were meant to be viewed at a distance. Try turning down the vertical height, and give it just a little bit of over-scan. It might be that the vertical height and or vertical lin, is set too high.
