Old 07-16-2013, 01:22 AM
In this set the electrolytics are 475 volts , i have a feeling that a 450 volt would be ok its just the start up voltage may go at or above 450 volts and then drop thats why they have 475 volt caps in there , i could always order 500 volt caps but just for testing and getting the set up and running i was going to double the caps using two 450 volt caps making it 900 volts handling , so that would be way over whats needed but the caps would be ok .
the dumont ra-103 , ra-103D and ra-110 all use a couple capacitors in series with 100k resistors on them , designers put that in to avoid a higher voltage capacitor.
mike
Old 07-16-2013, 02:07 AM
ppppenguin's Avatar
In theory a pair of identical electrolytics will tend to balance the voltages across them fairly well due to leakage and the way the insulating layer is formed by the application of voltage. In practice as others have observed it can go badly wrong, especially if one cap dries out. I'd probably use bleeds even if this wasn's strictly needed. What value bleeds? The current needs to be large compared to leakage and small compared to what's being supplied to the load. This is total guesswork but I'd probably bleed about 1% of the load current.
If you are using non-electrolytics in series to increase the voltage rating then bleed resistors are essential. The problem in some case may be finding high enough values to keep the wasted current down. For example if you replace a 100n 5kV cap in a TV with mains EHT using 10x 1u 630V then 10M resistors will draw 50uA. This may be excessive.
Old 07-16-2013, 11:07 AM
kx250rider's Avatar
REAL TVs have TUBES!
mike
Or what I've done in certain cases with fast-warming B+ rectifier tubes or solid state B+ supplies, is to modify the B+ supply to include a delay relay, so as the filaments are all up before the B+ comes on. That shortens the duration (or eliminates) the unloaded high B+ surge on startup.
Charles
