Old 06-05-2013, 06:58 PM
technicolor's Avatar
technicolor technicolor is offline
go big or go home
capacitor question on 49 rca
Ok, so i have been recapping my rca rutland and am concerned.
Two caps clearly are early electrolytics. The sides have metal ovals, and they are marked with a plus sign.
No i'm findind caps like these, that have one stripe and are marked on the stripe grd.
I'm confused as to if this is an electrolytic.
This is an all wax and paper cap, the sides are not metal ovals.
Old 06-05-2013, 07:12 PM
David Roper's Avatar
console lover
They are not electrolytic. The polarity is marked to indicate the outside of the foil, which no longer matters.
Ignore it.
tvontheporch.com
Old 06-05-2013, 07:22 PM
leadlike's Avatar
leadlike leadlike is offline
The outside foil can be used as a shield against interference. Here is a lengthy page on the subject:
http://www.aikenamps.com/OutsideFoil.htm
As previously stated, this isn't anything to really worry about when putting in modern poly caps.
Old 06-05-2013, 07:23 PM
This article has advice about identifying and replacing capacitors, with photos showing the various types:
http://antiqueradio.org/recap.htm
As David noted, you can disregard the "foil end" stripe, and the value (as well as general appearance) tells us that is not an electrolytic.
Regards,
Phil Nelson
Phil's Old Radios
Old 06-09-2013, 11:49 AM
kx250rider's Avatar
REAL TVs have TUBES!
Generally, the band goes to ground when one side of the cap is ground, or to the downstream end in coupling circuits.
Charles
Old 06-09-2013, 12:41 PM
dtvmcdonald's Avatar
I thought the band went to the upstream (source, plate, lower impedance) side
in coupling circuits, at least in theory.
Doug McDonald
Old 06-09-2013, 12:52 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
That's what I always heard and did, as well....
Old 06-09-2013, 01:01 PM
If it's for shielding, the plate is at higher potential than the grid.
Old 06-09-2013, 02:24 PM
What matters for shielding is not potential, but AC impedance. A plate typically has
effective impedance in the 1000-10000 ohm range, while a grid (class A) is
infinite impedance at least at audio and TV sync frequencies.
Now I suppose if you worry about insulation, not noise pickup, DC potential
would matter.
Doug McDonald
Old 06-09-2013, 02:28 PM
True, the plate is at higher DC potential. But signal wise, the plate presents lower impedance-to-ground than the grid which the cap is coupling to. Ergo, better shielding is obtained with the outside foil connected to the plate.
Old 06-10-2013, 12:00 PM
kx250rider's Avatar
I may stand corrected on that now that I think back . Not being an engineer, I will defer to others on the particulars here. I need to be careful about blurting stuff out in a hurry.
Charles
Old 06-10-2013, 03:26 PM
Charles
Don't worry. I been there, done that. Suffered a grand mal brain fart recently about Predicta 2V CRT heaters.
Old 06-10-2013, 08:00 PM
Dave S's Avatar
Dave S Dave S is offline
<-- Me and my "first" TV
While the occasional misstatement might show up every now and then, this forum is more like a graduate-level discussion on stuff like this. I came in thinking I knew a lot, but everyone kicking things around like this has made me a lot less ignorant than I used to be! This couldn't have happened twenty years ago. Ain't it wonderful? :-)
