Old 05-10-2013, 11:58 PM
The setup for a portacolor G2 screens is a bit different than most sets, the sams has you turn them all up full, then adj so when the brightness is turned down the low lights are not tinted, at least one control should remain at full. Then adj the green/blue (by the contrast pot) so when the brightness is back up to full the highlights still lack any hue (adj with a b&w program or a grey scale pattern is best).
The moving color bar sounds like a HK short in the difference amp tube or maybe something wrong with the degauss circuit (if its the auto one anyway).
Try subbing in a new color difference amp tube 1st.
