Old 05-08-2013, 03:47 PM
DavGoodlin's Avatar
Motorola Minion
Originally Posted by jmetal88 View Post
Okay, I took care of all the arcing I can see, but after the set has been left on for a while, I can hear a steady 'crackle' of arcing that I can't see anywhere, so the flyback may still be a problem. Also, I think I might need a new 'suction cup' lead, as I did actually see one arc shoot straight through the insulation on that thing, which is kind of worrying. Any suggestions on where I could find one of those?
That HV cup should be washed like a plastic dish, then do as I say below.
I did this to the flyback on my 1963 RCA Color roundie back in 1979, and when I fired it up about 20 years ago the HV came up without arcing.(it needs other work including a picture tube) Funny thing, 34 years ago, I assumed I would NEVER find a flyback for this set, so I stripped the arcing-tracked cover off the fly and brushed on about 6 coats of this stuff. I highly recommend it.
When in doubt, get the dope out and start brushing;..http://www.alliedelec.com/images/pro...S/70159781.pdf
Electronic M is right on..
Regarding unqualified alignments, I diddled my share of slugs to compensate for tuner, IF and video problems. I recommend getting a fact'ry schematic, scope, marker and sweep gen (Sencore speed-aligner) do it right. It always improves things. I will not tweak anything other than sound, burst or horizontal efficiency coils without the above equipment.
