Old 03-10-2013, 03:05 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
transformer needed?
Do I really need a matching transformer to hook a 1962 RCA New Haven up to a vcr using a coax. cable?I have using jumper wires to the ant. hook up. the tv is puuting a pic on the screen but the sound hums very quietly and the picture will not hold horiz. sync so far. I still have 5 original caps to replace, just need to pick them up at Fair Radio first
Old 03-10-2013, 03:18 PM
electroking's Avatar
a- v- karma member
Do invest in a transformer. You may find it still attached at the back of a junked TV.
Old 03-10-2013, 03:30 PM
radio nut's Avatar
Bought a new one on the way home earlier. Why do they need one?
Old 03-12-2013, 11:02 PM
For a VCR or digital tuner going to a TV, you could probably get away with just kluge-ing the coax onto the 300-ohm screw terminals. With a real antenna signal from a long piece of cable, it would make a bigger difference.
Old 03-13-2013, 01:02 PM
Been there, done that occasionally.
Yup. Gotta concur.
Last edited by old_coot88; 03-16-2013 at 01:09 PM. Reason: Changed "many times" to 'occasionally'.
Old 03-13-2013, 04:50 PM
Reece's Avatar
Reece Reece is offline
However those little transformers are cheap and available at RS, Lowe's etc. Makes a neater and more secure installation as well as satisfying impedances.
Reece
Old 03-13-2013, 11:43 PM
Yes, indeed. I keep plenty of spares around here, of both "genders", for hookup activities with older TVs and antennas.
Old 03-14-2013, 10:52 AM
Geist Geist is offline
Hi All;
I didn't know You could get them in either Gender !! I have seen only female..
THANK YOU Marty
Old 03-16-2013, 12:50 AM
Marty-
There are transformers with two screws for the 300 ohm connection, that push onto a female 75 ohm F connector. Those are the "opposite gender" to me.
