Old 02-13-2013, 09:33 PM
maxhifi's Avatar
maxhifi maxhifi is offline
Heater/Cathode Leakage testing
Been working on a couple old GE radios.
Typical cheap AA5 AM only radios from the mid 1960s.
My EICO 667 has been amazing for tracking down heater/cathode leakage issues.
For the first radio The 12BE6 failed miserably with 1M, and replacing it cured an annoying modulation hum issue I was dealing with. I also replaced the 50C5which had 5M leakage. The other three tubes all passed with flying colours.
What do the vetran techs use as pass/fail values? The 12BE6 made a big difference, the 50C5 much less.
Old 02-13-2013, 10:57 PM
bob91343 bob91343 is offline
It's a matter of the circuit and how much hum you are willing to tolerate. Each situation is different.
If I find a tube with noticeable leakage I try it and see if a problem arises because of it. If not, I use the tube. If I am working on a set for someone else I might be a bit more strict to avoid problems later.
Old 02-24-2013, 06:44 PM
Alastair E Alastair E is offline
For leaks H/C sometimes its possible to 'bias' the heater-chain more positive than the cathodes of the tubes, by about 30V--providing that one side of the chain isnt earthed to chassis .
The theory is it reverse biasses the 'diode' created between the leaky Heater and the Cathode.
This Ive done on a set some time ago where I couldn't easily get the valve to repair it properly.
It works fine.
