How long did the reformation process take on a typical electrolytic? Was there a reason for not measuring the leakage of the reformed capacitor? Comment: I've never reformed a "dry" electrolytic, but have done the "wet" ones many times. Many many years ago, the shop where I worked, found a small niche service of repairing 1930's radios and discovered that often the capacitors needed reforming. We built an electrolytic reformer completely out of salvaged and scrap parts. We jokingly called a redneck reformer! It was simply a small variac that feed a salvaged 325 volt transformer connected to opposite polarity diodes on each output. (The extra diode was because PIV rating could exceeded if one got careless.) It had a single 5 Mfd oil-filled cap to absorb some of the ripple and an surplus 0-500 DC voltmeter. Inserted in the line between the variac and the transformer primary was a lamp socket with a 5 watt lamp that functioned as a current limiter. We had a salvaged meter of unknown scale in series with the capacitor to be reformed. Across the meter was a wire wound pot. We calibrated that meter with the pot using a new electrolytic of the same value. Our goal was to reform the old electrolytic to where it leaked no more than twice as much current as the new one and the electrolytic had to not heat excessively. Depending on how long the radio had set unused, these took anywhere from 15 minutes to three days to reform. (We shut it down when no one was in the building so a day might be as little as 6 hours.) If the capacitor shorted, it just lit the lamp and did no harm. We could usually tell within one minute if the reforming was going to work. I do not remember any call backs from the owners of these radios for failed filter capacitors. We had a printed note with bill athat stated that the set should be run for at least one hour per month to keep it in operating condition. We stapled the carbon with their signature on it to our copy of the receipt. James. |
