Old 01-31-2013, 12:50 PM
I think as a CRT wears out, that the control grid loses it's ability to effectively control whatever emissions the cathode is still capable of producing. So the picture becomes more and more washed out. Ability to focus goes out the window too. You ultimately end up with a leaky valve and a low water supply, or so it seems.
Old 01-31-2013, 04:11 PM
In some cases of extremely weak cathode emission in a B&W CRT, the pic is so dim it can only be viewed in a darkened room. The pic will have a 'silvery' cast, and high-luminance parts of the scene will actually be photonegative. That's because the control grid is commanding high beam current which the cathode can't deliver. And the grid is actually pulling available electrons out of the beam.
Old 02-06-2013, 02:52 PM
DavGoodlin's Avatar
Motorola Minion
This explains pretty well what some texts referred to as a "gassy" CRT or one not under full vacuum..
so maybe gassy is incorrect , otherwise you may see some violet glow in, but not so much around, the electron gun.
Is this the same reason for the color smear (when increasing brightness/screen/bias) when a corresponding gun is weak in a color CRT?
Old 02-06-2013, 04:42 PM
All the cases of extreme weak emission i've ever seen did not exhibit signs of vacuum loss or purple glow. Weak emission and 'gassy' are quite different critters.
You'll see this sometimes in a solid state set with a weak gun when someone, trying to compensate, has cranked up the driver transistor for that gun. That can cause the transistor to saturate on peaks, resulting in the trailing smear. I don't recall ever seeing it on a tube type set.
Old 02-06-2013, 06:10 PM
It's the ability of the cathode to supply electrons that deteriorates, not a change in the ability of the grid to control them. The control ability is determined by the spacing and size of the electrodes, which doesn't change as the tube gets older. (There can be problems if cathode material migrates to the grid and the grid itself starts to emit electrons)
In a good tube, electrons form a cloud in front of the physical cathode, and the grids control flow from this cloud. When the emission gets too weak, this cloud can be depleted by trying to pass too much current in the bright parts of the picture.
