Old 01-28-2013, 01:48 PM
I have a Velleman (Chinese/Japanese (?) off brand) DMM I purchased from Amateur Electronic Supply in Milwaukee several years ago. It still works well, but I make certain what position the range switch is on before I connect the test probes. I charred some parts and melted the casing of the zero adjust pot in a cheap Radio Shack analog meter I had in the 1970s when I neglected to change the range setting (on this meter one changed scales and ranges by connecting the probes to different jacks on the front of the meter -- that's how cheap the thing was) when trying to measure the line voltage at one outlet in an outlet box in my workshop at the time. I knew I was in trouble when I saw a thin plume of smoke rising from the ohms range jack. The meter, amazingly, still worked well for some years afterward.
That taught me a lesson I knew I'd never forget, and now I make absolutely certain my meter isn't on ohms or the wrong voltage range for the voltage I am trying to measure. I realize these meters are fused against mistakes and/or accidents, but I am sure it is still possible to damage the instrument beyond repair if the voltage being measured is far too high for the range you selected -- say trying to measure B+ voltage on a radio/TV tube with your meter set (for example) for 1.5 volts full scale. Such a severe overload, of course, will blow the fuse, but probably not before damaging other parts of the instrument first, as the fuses used in these meters do not, as a rule, act quickly enough to prevent damage to sensitive components, especially when the meter is severely overloaded. With today's solid-state DMMs, such an overload would probably ruin the instrument in no time flat. There is one range on my DMM that is not fused; of course, if this is overloaded, the meter will be destroyed in an instant.
I wouldn't use a DMM to measure voltages near the HV plant in a television set, the reason being it is far too easy to accidentally brush against the 2nd-anode connector of the CRT or other parts of the HV system with a test probe; this, as one other person here has noted, will put the meter out of commission in the blink of an eye. The meter's internal fuse(s) may blow at this time, but by then it is usually too late; the damage may have already been done.
