Is it mostly the tapes recorded on the HS-400UR you are having trouble tracking? Those Mitsubishis were always a problem keeping the tape path in alignment because of the design.
I have a HS-430UR that was one of those problematic VCRs too. Also with any SP recordings made on that 400, that model only had two video heads not the wide heads for SP like the 430. So those tapes would play a little weak maybe more grainy or snowy with a VCR playing back with the wide SP heads. If you had one of the "Dynamic Drum" JVCs I think one of those would adjust itself to track moderately out of alignment tapes.
