Old 10-24-2012, 09:47 PM
The man behind that website used to come on here sometimes but I haven't seen him for a year or two. Well done site.
Kam, I agree on that cap being the problem. Even if it isn't, it needs to go. I had one blow on mine. The set kept playing but with a dark, screwy picture. I have had some 50s radios where a bad cap would keep blowing periodically. The set would play fine, jut every so often BANG! Good for a laugh, depending on who is in the room at the time!
Old 10-24-2012, 11:08 PM
marty59's Avatar
marty59 marty59 is offline
The dual AGC/Height control will wisker over and "bang" also. There's B+ Boost on that height control wiper. Sometimes in a dimly lit room you will see the flash!
That control comes apart quite easily for cleaning.
Old 10-24-2012, 11:20 PM
ctc17 ctc17 is offline
The color is superb for one of these sets!
Of course it still looks like you're watching it through a Screen Door but that's just the way it is.
HAHAHAHA, yea thats about it! I have several of those things floating around here. At that price I should ebay them all before the dollar fully goes down the toilet and no one can afford novelty junk.
Exactly on the whiskers, every one I have seen had whiskers in that agc/vert combo pot thing. I usually blow them out with b+ but the correct way is to open it and clean it up.
Sylvania is another brand that Always has whiskers in the pots. They use that same 3 pot assembly and they are always shorted.
Old 10-24-2012, 11:29 PM
Originally Posted by AiboPet View Post
Yeah Kamakiri. These were REAL little tubes. I think I remember them being like two inches tall, and only about as big around as your finger. They were loose, so have NO idea what they were from, but they sure were cool to look at.
With my collection, I don't own ANYTHING with tubes in it since I [stupidly] gave my old Hallicrafters S38 to someone like ten years ago.
I was sort of assuming these "Compactrons" were real little like this. I've seen and even worked with a couple old tube GE sets when I was a kid....but they really only had very pedestrian problems like dirty pots and tuners, an occasional "playing" with purity and geometry. Back in the early '80s....most of these sets weren't really old at all and recapping just wasn't something that ever came up unless you saw big visible hum bars or something. Not real sure if the little GE set I had for a short time as a kid was a Portacolor. It WAS a tube set.....but like 12" (color)....and was actually quite robust to all my "banging on it" as one of my "student" sets I brought into that class.
I bet you are thinking of subminitures and acorn tubes. I picked up some military aircraft locater thing thats just full of them. I even have a military tube tester that will test them.
There were some radios made that used them, I think motorola? Someday I want to build something using them.
Compactrons are a regular size tube with 3-4 sections jammed inside. There was an AM radio made that had 1 compactron that did everything.
IMO GE made good tubes and the compactrons were reliable
Old 10-25-2012, 07:11 AM
AiboPet's Avatar
AiboPet AiboPet is offline
"micro" and quirky
Location: I'm in San Diego, but lived in Hong Kong for a long time
Cool!!....Sounds like the "integrated circuit" of tubes. Pretty sure I have never seen one then. Sounds like it would have a wild socket since I would imagine it can only share the heater pins. An AM radio with just one tube would be fun to run "open frame" so you can see the one tube light up. So were the Compactrons seperated in a "pie" configuration?...or were they "stacked" inside.
Update:
Did an image search on Google. I'm surprised these actually are in what look like just regular sockets. Couldn't really tell how the "sections" were laid out from the pics...but my experience with tubes is almost ZERO since the class in the early 80s. Growing up in Hong Kong, and coming to USA to live in yet another flat....I've just never had the room for the sets I "really" wanted to have (BIG long consoles).
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P
Old 10-25-2012, 09:49 AM
The 1953 Motorola clock portables used sub-miniture tubes. Three sub-minis plus a 3S4. They also built a small portable radio with three sub-minis and a 1R5. Strange!
Several other firms used them around the same time frame.
Old 01-14-2013, 11:33 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Originally Posted by zenithfan1 View Post
Hey Tim, there are a few of those white ceramic "time bomb" caps in there. Some are in the horizontal out section and are located toward the very back of the chassis by the controls. Mine had one blow up and the same symptoms and description as your set was the result. It was very easy to fix, took 10 min. I forget the cap values now, .1@1000v or something......
Right now, I've got the set in "fear factor" mode.....mainly because the inside of the set was so gummy with tar
The ceramic cap to the far left on the chassis appeared to have some oill leaking out of it.....I've got replacements from Digi-Key going in today, and hopefully, reassembly.
Any tips on (attempting to) clean this chassis? I may just scrub the case, clean the tubes, and throw it back together.....but I hate leaving a job undone in that regard......
Old 01-14-2013, 12:09 PM
Yikes!! did you try it before taking it all apart? I have had two of those and they both were dirty as hell and worked fine (with orig caps, I did replace the one ceramic one on the back).
If anything goes wrong and you cant get it back working AND decide you don't want it let me know. I am looking for a CRT for one.
Old 01-14-2013, 12:11 PM
hmmm went back and re read your post (did not see how old this thead was), Mine did make a few loud pops but that has stopped and its fine now. Looks like you may have more issues
Old 01-14-2013, 12:17 PM
Kamakiri's Avatar
Hm, I dunno.....nothing that makes a loud POP has no issues, just ones that haven't surfaced yet .
Mine popped the moment I plugged it in, but I tried it a second time for the heck of it. After an hour or so of playing, the scenario that I wrote up came to pass.
It just LOOKS like a mess. In reality, to take the chassis out, is a matter of desoldering 4 wires, one spade terminal, and one ground wire (IIRC). The whole chassis HAS to come apart to effectively de-tar the case, and as I'm sure you know, the wires that connect everything together are REALLY short, which ends up making everything look like a jumble once it's all out of the case
Old 01-15-2013, 08:46 AM
Kamakiri's Avatar
Moved this thread over, as it's now becoming more of a technical discussion, or, from this point, a
Got the set repaired and reassembled yesterday, and powered it up. Slowly, it came to life....I say slowly because I must have jarred the controls way out of position, and I had to tweak everything. It started to get a picture, then BANG! You'd swear there was a firecracker inside the set. Scared the bejesus out of me!
But then the picture pulled in perfectly....perfect color, the vertical locked dead on, and everything was excellent.
What.....the....hell!
I pulled the back this morning, and it wasn't the new film caps I installed, because they're just as they were. What the hell kind of BANG can cause a set TO work properly? Usually, it's the opposite way around!
Pics of the set assembled, and then working perfectly after it threw out a loud sudden cough
Old 01-15-2013, 08:55 AM
Bill Cahill's Avatar
Super Moderator
Post
In all probability, one, or, more of the back controls has "tin whiskers" shorting out the B+ causing the loud explosions. Nof goof for either the controls, or, your electrolytics. This is a very familiar problem on these GE Porta Color sets.
You could try dismantling the controls, and, cleanning them well, including with a soft tooth brush, or, replace the trouble makers.
Bill Cahill
Please join my forum.
Old 01-15-2013, 01:26 PM
I bet you are thinking of subminitures ... Someday I want to build something using them.
I did that, see my web page http://pw2.netcom.com/~wa2ise/radios/AA5submini.html
and compactrons http://pw2.netcom.com/~wa2ise/radios/compaa3.html
Old 01-15-2013, 04:29 PM
Kamakiri's Avatar
Bill Cahill
Replacement seems like the best way to go. Now, where do I get my hands on some of thae critters
Old 01-15-2013, 09:53 PM
Kamakiri's Avatar
Well, it's not looking good
I was watching the Portacolor today for about a half hour, then a firecracker went off
BANG
Lost the raster and sound. Powered it down quickly.
Opened it up just for a quick visual. Nothing seemed blown. Based on what I've done so far, any thoughts?
