Old 10-09-2012, 10:22 PM
Telecruiser's Avatar
Telecruiser Telecruiser is offline
Originally Posted by XDCAM View Post
At closer look it is a carcass .If I was you, I would make contact with this seller as he deals in Old Gear .
I have sent him a message, but so far, no reply.
Old 10-10-2012, 02:08 PM
XDCAM's Avatar
XDCAM XDCAM is offline
Originally Posted by ppppenguin View Post
I assume you mean the EP8 pulse connector that Marconi often used on their kit. Paul Marshall is the man to give an authoritative answer but I think it's:
Pin 1: Line (Horiz) Drive
Pin 7: Field (vert) drive
Pin 5: Mixed blanking
Pins 3 & 8: Ground
Other pins unused. Mixed sync has its own PL259 conenctor.
Thanks
Old 10-17-2012, 03:39 PM
XDCAM's Avatar
Vidicon
Does anybody kown the difference between the Vidicon CCU/Power Supply (Looks the Same) as the MkIV Image Orthicon 4.5 inch set please .Just Rescued these from being dumped .
Old 10-17-2012, 04:35 PM
BrianSummers's Avatar
BrianSummers BrianSummers is offline
TV Camera Museum Curator
Well saved! They are quite similar but I would need to look at the circuits, there will be lots of detail differences. The vidicon head BD896 had a smaller power requirment than The I.O. also the tube suppies were simpler than the I.O. I ll try to find what the differences are.
I have a MkIV vidicon head, but no CCU or PSU so if you could do some pictures and send them to me I would be able to add them to the camera museum.
regards
Brian
www.tvcameramuseum.org
Old 10-17-2012, 06:01 PM
XDCAM's Avatar
Thanks Brian
Thanks Brian for the quick reply .It is amazing whats turning up all over the world with the digital up grades .I got no control panel ,it went in the other skip with the Head .
Old 10-18-2012, 05:06 AM
I have had a look at what handbooks I have in the museums library, the CCUs look very similar having most of the modules with the same number. Sheet two of the CCU drawings, the plugs and sockets on the rear are different, the vidicon one has fewer connectors.
I do not have a drawing for the vidicon PSU, it is in Marconi book T.3975 (hint) but looking at the PSU for the I.O. camera it is mainly the +250volt supply which could be the same, also in the I.O. PSU are the focus, talk-back, and Iris amplifier, these are likely to be missing or different. I have a vague memory that the space is there and they are just not fitted.
So I do think there is a lot of items in common. I can also confirm that the vidicon control panel is the same size and style as the I.O. control panel, but with fewer controls. It is a very attractive panel with black perspex and the lettering is illuminated by bulbs set into the perspex. I do have a control panel for my Mk IV, must do photos of it sometime.
If you are able to do some good high res photos suitable for inclusion in the museum I would be pleased.
Brian
Old 10-19-2012, 01:04 AM
XDCAM's Avatar
Been told that the PSU is the same .Not CCU . It was in their sales book apparently .
Haven't given up on the Head yet as it may turn up in E-wast I been told !
Old 12-04-2012, 03:45 PM
XDCAM's Avatar
Looking for parts
Does Anybody know of a Camera Head that is (Beond repair) Parts .Looking for a Camera Door Cable Side .
Old 12-04-2012, 08:33 PM
XDCAM's Avatar
Originally Posted by BrianSummers View Post
I think at least 916 were made, and without thinking to hard I can account for at least 9 , I only have one. It is quite surprising how many are hidden away. It needs some thorough counting to establish how many are left.
Brian
Hi Brian, Are they all Full Chains (9) . Looks like these are the Only survivors .
Old 12-07-2012, 03:30 PM
Mine is a full channel viable with all the parts needed, except time!
I know that two of the others are complete, most people say I've got a MkIV and don't go into detail about CCUs etc.
Brian
Old 12-19-2012, 04:10 PM
XDCAM's Avatar
Offered
Can the person that sent private Message .Please resend ! Or Call my IRLP Again Please .
Old 01-07-2013, 01:29 PM
XDCAM's Avatar
This thread seem,s very popular (3,190 Views).It looks like the final Count for Complete Chains as of (05-30-2012)
UK=5 Chains 4 Known of. Heads 5 (I know golden-agetv.co.uk have 6 ) 1 Chain from NZ
NZ=5 CHAINS 4 HEADS Known to be about (Mine Ex BBC (A/B) and NZBC (J) suffix
AUS= Nearly 1 Chain 2 Heads
Brazil =1
USA/Canada =1 Chain 6 Heads
(That means that their are Only 11 Complete Chains remaining out of 916 made.)
If you have more please post !
Gibraltar=1 Looks like 1 more Head according to this Photo http://www.facebook.com/photo.php?fb...7768249&type=3
I have recieved One of the Chains in the NZ Count (It Pays to Advertise ) all I wanted was a Door(Still wanted) .This Camera is a late Model J (625 Only) and is Complete (In time I will Soak test her).
What are the Known Age Faults to look for please (Apart from Caps & Resistors Valves).
Old 02-21-2013, 12:16 PM
Paul B Paul B is offline
looking to bye a MK IV
Hi all looking to bye a MK IV camera head / chain to go with my MK VII
also looking for MK VII Power Supply to get camera working also looking for lotes of good luck regardes Paul B
