I think 1958 may have been the first year with a 318 cubic inch V8. I had a radio from one when I was 11. It was a Motorola with a bright white slide rule dial and a square profile from the side. It worked great on my HO model train transformer since the radio's vibrator supply filtered the DC.
http://www.allpar.com/history/chrysler-years/1957.html Some lovely "Finned Mopars" shown in the article. jr |
If the Mopars of that era were "Willowy", the T-Birds & Lincolns were NOT. They were almost laughably OVERBUILT... The '58 Lincoln was pushing 5300lbs, Ford has to make a GINORMOUS 430 CID engine to be able to make the beast able to get out of its own way..The '58 Lincoln had the LARGEST unibody construction ever attempted to that point..I think only the Mercedes 600 series from 1963-81 ever exceeded them in size..
Benevolent Despot |
AFAIK the unibody came out in 1960. Torsion bars in 1957. Kool Kar. |
The early ones were the "A" block. The newer ones were "LA" block, which meant "light weight A". LA engines were introduced in 1964 as the 273. A while later they were bored and stroked to 318 Cu. That engine also became the 360 and the V-6 and the V10. |
My Mom's 65 Belvedere had that wide 318, the one with the bolts through the valve cover, primitive looking beast compared to the modern small block version.
I always heard them called the Canadian 318 but I don't know if that's true. |
The last year for OEM Motorola radios with vibrator P.S. was 1956.
![]() The tentative plan here is to stay with the Savoy trim, but do the red and white paint scheme. Depends how the car looks, though, once I get it here. I want not only a fantastic looking car, but something that's very roadable....which means that the front drum brakes are going to be replaced with a bolt-on disc conversion, and I'd like to yank the original engine and replace it with a somewhat more modern Mopar V8 with dual exhaust. The motor in this car is literally half apart anyway, so doing it that way will save me both time and money. If the car has vacuum wipers, they're history, and no bias ply tires this time .Resurrecting the Buick has taught me a LOT about how to build a car to be a daily driver, or since I live in Buffalo, a summer daily driver. I'm not going to do anything stupid to the car, but some things are going to need updating. I saw the picture of Lee's car, and two things are apparent. First, that he's a purist, and to be commended for that. I'm also betting that his car didn't start out a rebirth as bad as mine is, or if it did, he's got deeper pockets than I do . Either way, if it's the car I think it is, it's as perfect as I've ever seen....
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
I saw a black 1961 Impala 4 door flattop sedan today, that looked spectacular, except for those ungainly gigantic custom wheels and skinny tires. Leave those off of nice cars, put them on something newer and more common please.
Good for you buddy,i reckon you will fix her up nicely
When I was (way) younger we had a '61 Fury with a 4BBL Polysphere 318 and that thing would run! When the 318 became the LA smallblock, it became pretty much a Mom an Pop utility engine with only a 2BBL until the later M-Body Copcars were available with 4BBL's. |
, a Mopar weak point.
Benevolent Despot |
My Parents had an Auto Salvage yard in the 70's, a lot of now classic cars went through there, some were bought and saved by collectors, others were stripped and crushed! I remember being upset when they donated a 51 Pontiac Station wagon with a Flathead straight 8 for the Demo Derby, it was running of course. Then there was the pristine 58 Chevy Wagon that had to be crushed intact because it was a Police Impound with no papers (mostly intact anyway, I hear a few parts got away) |
The 1964-66 Imps were designed by Elwood Engel, who had also been instrumenta lin designing the 1961 Lincolns...THAT'S the reason the Imperials kinda looked like the Lincolns...When I bought my 1st "Suicide Door" Lincoln in Dec. '82, it was a Chevy/GM dealership where the old guy who owned it had a fondness for Mopars...There was a Airflow Chrysler that wasn't TOO bad, a Superbird, a '65 Imperial, another couple of Mopars that I can't recall now,& the Lincoln...The Imperial got a pretty good lookin' at by me, but in the end I went w/the Connie-Gotta LOVE them suicide Doors, y'know...That,& I think he wanted $2500 for the Imp- The Connie was $1K. The old Airflow, he only wanted $5K for, & it was in running condition...Don't remember what he wanted for the Superbird, but it was likely WAY beyong my meagre budget.
Benevolent Despot |
