Old 10-26-2012, 06:34 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
As long as I'm using it around TV sets and their HV supplies it makes no sense to use an expensive meter...
A big part of the increased cost of better grade multimeters is better input protection circuitry. MOVs, PTCs, gas tubes, clamping diodes, and fast acting fuses all cost money, but they help your meter shrug off the occasional overvoltage or "checking voltage on the ohms/current range" type incident.
Better internal shielding can help a lot for this kind of work, as well. I have seen a few cheap Chinese meters that go completely nuts when they get anywhere near a tube type TV chassis. The radiated signal from the horiz sweep/HV circuitry gets into the meter and causes all kinds of wacky readings.
