Old 08-15-2012, 07:36 AM
1966 motorola 23 inch color
i have this motorola color and it works fine since i got it done but it always had little red streaks of red on the edges of whites. i have not figured out why or how to get rid of it. all the other colors are fine just the white. any ideas anyone? if i post a pic it may not be seen.
Old 08-15-2012, 07:57 AM
ctc17 ctc17 is offline
Does it go away when you turn the color down?
If so good chance its the crt. How are the emissions at 5 volts? If the emissions show good at 6.3volts but sharply drop off as you lower the voltage to 5 I would be looking at the crt.
Red bleed and smearing are one of the signs of a tired crt.
Old 08-15-2012, 08:14 AM
with the color down the last i tried it still was there. ill have to try the crt test at 5 volts.
Old 08-15-2012, 08:24 AM
Color down = convergence?
Yea always test down to 5 volts. A usable crt will show good at 6.3, a strong crt with good life left will show good down to 5 or lower
Old 08-15-2012, 08:33 AM
i did have a hard time converging this set as its alittle different then the rcas and i have tried to get that red smear out when i converged it but no good. so it could still be a crt issue?
Old 08-15-2012, 09:00 AM
Not if its doing it with the color off. Unless itts a crappy rebuild and it won't converge right.
Old 08-15-2012, 09:08 AM
I agree, looks like a convergence issue.
Old 08-15-2012, 09:21 AM
hmmmmm,
Old 08-15-2012, 09:41 AM
hmmmmm,
Give me the model number, I have a load of motorola factory service data and it may have better instructions on the convergence. Sams are 'quick and dirty' when it comes to detailed stuff.
Old 08-15-2012, 09:57 AM
its a 1966 908 chassis with the converge adjustments in front, i dont like this setup. the sams states to use the bar gen and then make the final adustments in the front as well as the 2 drives in the rear to get the best black and white pic.
Old 08-15-2012, 10:47 AM
reeferman's Avatar
I worked on a lot of 23" Motorolas and they sets were notorious for having bad tube sockets, especially the ones along the rear of the chassis (demods I believe). Tap (all) the tubes with the handle end of a nut driver and see what happens. Hopefully nothing. Let us know.
Old 08-15-2012, 10:51 AM
DavGoodlin's Avatar
Motorola Minion
I believe a Motorola Guru by the name of Forest H Belt wrote a book on servicing Motorola's. It was a Tab Books (now McGraw Hill) and no doubt out of print.
My $.02: If you turn down the contrast or brightness and the schmear goes away, the CRT may need a "kid-gloves" belt with your CRT tester.
Is this CRT a 23EGP22?
Old 08-15-2012, 11:09 AM
yes its the 23egp22 and was rebuilt in 1982. KIDS - GLOVES, ? booster ???
Old 08-15-2012, 11:43 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
kid gloves= gently, lightly. he means use the lowest restore setting on your CRT tester and zap it. usually the "clean" function.
Old 08-15-2012, 11:55 AM
hmmmmm, even if it shows good already????????????? what do you think dan?
