  #35
Old 07-30-2012, 05:54 PM
ctc17 ctc17 is offline
Is there static and snow if you disconnect the antenna???
I have a 16 that had a open 150 ohm resistor that fed the first IF its plate voltage.
The set worked fine with no voltage on the first IF tube but kinda acted like you are talking about.
A radical sensitivity to different tubes would indicate a fault in the circuit.
Why dont you do a dc voltage measurement check on the first and second IF
