Old 07-25-2012, 05:09 PM
Reece's Avatar
Reece Reece is offline
Well, I finally got this ironed out!
Backing up a bit: when I first opened the set I searched on line with the model number and found a blog where a poster described the exact same symptoms. He checked the electrolytics in the vertical section and found them all lower in value than marked. He replaced them all and the resistor which was the subject of my post; his resistor had gone high. He also stated that the board trace from pin 7 of the vertical IC was lifted and open and he repaired that. Changing all the caps, the resistor, and repairing the trace fixed his set.
Then on the same blog another poster stated that his set had the same symptoms, including the lifted trace, and he did everything the first poster had done and fixed his set, too. That's why I ordered the parts that I did.
This morning I spent about two hours on the board. I knew that I had installed all the electrolytics right as I triple checked each one off of a list and made very sure that they were oriented right. As it turned out all the 'lytics in this set face the same direction WRT polarity.
Then I checked the ribbon cables from the main board up to the CRT socket board. Sure enough, one wire did not have continuity. I repaired that. Then I went to inspect pin 7 of the vertical IC. I could ring out every other pin on that IC to its first connection point except 7. It took a magnifying glass to follow the tiny trace around and about but finally found where it terminated, and it rang true, also: nothing to fix there.
Next using clips I hung the 6 ohm / 2 watt resistor that Mouser sent me across the famous inscrutable one and turned on the set. It worked! The parallel combination of old and new resistors was about 4.9 ohms, right in the ballpark of 6. So I pulled the old and installed the new resistor.
I have a digital OTA converter in the shop for testing TVs and hooked this up with rabbit ears to the set and let it cook for a couple of hours. Everything seemed fine, good picture and sound. There is a reflection on the screen in the pix below and the lines are just interference between the digital camera and TV scanning. Not bad for a set I got for free!
Thank you all for your suggestions!
Reece
