Old 06-17-2012, 07:41 PM
the CTC-22's damper is a big honkin' thing that clips into a holder like a fuse. It has to be big and robust since it carries the full supply current of the HO tube just like a tube damper does. ....
If the output is a tube, then the damper could also be a tube. So my idea wasn't so crazy. If there's enough room to install it. And if you are willing to modify the set this much.
Old 06-17-2012, 08:13 PM
Not at all. All it'd take is a 6.3V heater xfmr and a tube like a 6DW4 with a stand-off socket...
...If there's enough room to install it. And if you are willing to modify the set this much.
