Old 06-04-2012, 02:20 AM
The IF in jack has an RG-6 or similar cable looped from another jack (maybe IF out?), that is visible in the first picture. Essentially, the unit is two things: The modulator with its fixed-frequency (IF) output, and a variable-frequency ("agile") converter that changes the IF to whatever channel you want to use. These devices can output all of the VHF channels and dozens of cable channels as well as UHF channels up to 550 MHz (so, up to maybe channel 27?).
All of these devices I have seen do have "baseband" (composite video, and audio) inputs. You will probably need to add two RCA-to-F adapters, since the inputs are F connectors also if I remember right.
