Old 04-27-2012, 02:25 PM
I also have a 01A tube with a broken off grid lead. I can see the little wire flopping around inside. If I can just weld it back on....
I finished rebuilding the filter cap.
I also painted the filter choke. It's not quite right so I'll try another color. Something a little darker.
Old 04-29-2012, 12:27 AM
When I tried testing this type 26 tube, I found dead short between the plate and filament. I pulled off the base to investigate and found the plate lead wrapped around the other 3
I untwisted it and reattached the base. Success!
Old 04-29-2012, 01:00 AM
Dang. That's a first for me. Somebody musta tried to unscrew the tube.
Old 04-30-2012, 06:43 PM
LOL - Maybe
Removing the RF coil assembly is fairly easy and really opens up the chassis.
The 0.5 uF caps in the box are leaky, but all the coils and small (mica?) caps test OK.
Grid leak resistor is a little high at 7M so I replaced it with 4.7M.
The cap box was easy to unmount and unstuff.
Old 04-30-2012, 07:52 PM
You didn't happen to but it from the user TubeTwister did you? LOL.
Old 05-03-2012, 02:41 PM
LOL - no it came with the set.
Here are the news caps for the tuner chassis filter.
The SPU is finally rust free
I switched to some Rustoleum Leather Brown paint. It's pretty darn close to the original but too glossy. I'll knock it down with a satin clear coat.
Old 05-03-2012, 07:43 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Superb job thus far, Definitely a RCA Radiola 18 chassis. Beautiful sets.
Old 05-19-2012, 03:07 AM
Thanks! I thought I was just about done with the painting when the final coat on the chassis crazed. When they say to wait 48 hours they mean it!
I only waited about 36 plus it was down in the 50s up in the attic where I do my spraying.
Oh well, I'll sand it down and try again. Then I can finally start putting it back together.
Old 05-19-2012, 10:51 PM
vintagecollect's Avatar
just awesome job on restore, I always wondered if this was an RCA clone, rarer tho..
That set will work for many years afterwards. a lot of sets have been parted out to scrounge for some money.
The first modern sets, battery sets w/ power supply are involved.
1977 Zenith Chromacolor II
A Very Modern Zenith
Old 05-25-2012, 02:38 AM
I'm finally done painting the SPU chassis and can start the re-assembly!
It took longer than I expected, but I'm happy with the results
Old 05-28-2012, 11:58 PM
I finished reassembling the SPU chassis and am happy to announce that it actually seems to work properly
I'll be installing a reproduction cloth power cord. Just a bit more work left on the receiver chassis.
Old 05-29-2012, 07:33 AM
Reece's Avatar
Reece Reece is offline
Boy, that's pretty. And look at that big honkin' globe 80. I've got a couple of them.
Reece
Old 05-29-2012, 02:23 PM
Thanks. Unfortunately, this 80 is a bit gassy and on it's last legs. Prices have really gone through the roof on globe tubes lately.
I'm tempted to throw a couple diodes and a dropping resistor underneath rather than put an ST 80 in there.
Old 05-29-2012, 02:24 PM
holmesuser01's Avatar
Wanna do another one? That one is beautiful. Mine has its original UX-280 in it. Has the little 'B' etched in the base.
Old 05-29-2012, 03:22 PM
LOL - Not anytime soon. This one has taken much longer than I expected with all the rust removal and painting.
I hope to have it running in a few days.
What does the 'B' in the base mean - Brunswick ?
