Old 05-07-2012, 07:08 PM
Magnavox300's Avatar
Magnavox300 Magnavox300 is offline
..better in black & white
Unidentified Cracked Part in Chassis; Magnavox 1960 TV
I am sure this is an all too common part, but since I am new to this hobby,
I have no Idea what it is.
It looks like a glass or plastic capacitor or resistor, maybe neither,
with copper windings inside, and it has a small crack running along the bottom.
I just replaced most of the capacitors, should I worry about this?
Also, the light blue rectangular resistor next to it looks worn, should I replace it, or do they commonly look that way.
Thanks for any help!
Magnavox300
Old 05-07-2012, 07:27 PM
I don't think there's a problem with either component. The clear item is a peaking coil. If there's a continuity reading, it's a strong possibility it's good.
Old 05-07-2012, 07:38 PM
bob91343 bob91343 is offline
Yes it's an inductor and should measure a low resistance. The white item is a capacitor, if I am correct to which part you refer, and it looks fine. If you are worried, disconnect one end and measure it. It's marked with capacitance, 0.1 microfarads.
Old 05-07-2012, 09:47 PM
teevee's Avatar
teevee teevee is offline
Both probably fine. The resistor is just a bit grungy, no worries. If you're worried about the cracks on the coil, a little service cement would seal them up so no moisture get's in and causes corrosion..
Old 05-07-2012, 11:16 PM
Thanks for all the excellent responses,
good to know what a peaking coil is!
I wonder, are they made of glass or plastic?
Magnavox300
Old 05-08-2012, 12:17 AM
A peaking coil, at least this one, is likely made of insulated copper wire wound on a cardboard tube, sometimes with a magnetic core. Copper wires soldered on the ends and the whole thing impregnated in some kind of plastic goop.
Old 05-08-2012, 10:29 PM
Thanks!
