Old 05-06-2012, 10:07 AM
So whats it gonna be, to pull or not to pull that is the question (main board).
FYI I was able to recap all but one IIRC and it was a white tube cap mounted vertically. I clipped the top lead, checked it with the eye tube, it was fine so I just used a pig tail coil to reconnect and left it alone.
On mine the thin cap by the power trans was open the others (doubler and 4 section in the front of the chassis) tested fine so I left them, still works fine a couple years later with reg use.
I think if I really wanted to do it right I would clip each wire that is pig tailed to the PCB (leaving the wire wrap along) and attach a anderson power pole connector to the clipped leads. then would look into a way to attach the board with screws and have a ground buss connector. That is IF i wanted to pull the board.
