#31
Could be a internal connection going bad?
"IPC 610 Class E & J STD-001 Certified" |
#32
I think so..
I cleaned the flyback even more, and it exposed this. http://img.photobucket.com/albums/v3...n/IMG_0403.jpg Yep, it's cracking and falling apart... So I need a new one.. Anyone have a FCM-2015AL? For safety reasons, this TV has been set aside and im using my hybrid set again. Last edited by lnx64; 04-29-2012 at 03:57 PM. |
#33
#34
Are they going to be reliable? I want to go by what radiotvnut said about cheap ones.
I found a HR one, but it's nearly 33 dollars and not even in America. If this one at ACME works then I'll use that, I just don't want flybacks blowing up when watching TV. |
#35
![]() I dunno if you tried this already,but have the set on with the back off in a dark room and see if you can see it arcing?
#36
I have no idea, I would recommend not getting it then.
#37
I did try it on with the lights off, but saw nothing. It took my hearing bamboo stick to hear it even coming from the flyback at the back section.
Dave, I contacted that company via Email, I'm gonna see if they will let me come and see the flyback in person.. |
#38
Your only choices may be the HR or the cheap one. The demand for flyback transformers has taken a nosedive, since the DTV switch; and, they are somewhat harder to find than they were just a few years ago. I think I ordered a flyback from that Acme outfit and it worked OK; but, I can't speak for how this one would work in your TV.
The ones I had the most trouble with came from a place called Dalbani. I got one generic RCA flyback from Tritronics that blew up within a few hours. The generic looked nothing like the original and it was a real pain getting the pins to line up with the holes on the PC board. |
#39
Ill probably do the acme one then. I still want to see their flyback first though. Some of the cheap ones dont have an anode wire long enough for this tv.
#40
Hope everything works out for you! Good luck!
#41
Thanks.. Sucks that today is Sunday, they likely aren't open.
#42
Placed an order for the HR one on the Ireland site (only site I could find that even had the HR one).
I want quality, and the ACME place don't allow local pickup, and won't show a picture of the item, thus they lost my sale. |
#43
Hey, quick question. Due to me having some hearing issues, and closed caption not always being the best solution, I would like to add a headphone jack to the side of this TV. I used to have an old 19" rotary when I was a little kid that had one on the right side. I would like to add one to this TV, and I could easily make a perfect clean round hole for such a jack. That's not a problem.
The problem though, is how the heck do I wire it to this speaker? It's an 8 ohms speaker. I can easily probably use one of those mono ear buds. How can I wire in such a headphone jack? EDIT: Also, upon removing the old flyback, how the hell do you remove the focus wire out of the CRT socket?! Last edited by lnx64; 05-01-2012 at 06:13 PM. |
#44
Ok, so Flyback disassembly has started.
http://img.photobucket.com/albums/v3...d/IMG_0413.jpg http://img.photobucket.com/albums/v3...d/IMG_0412.jpg http://img.photobucket.com/albums/v3...d/IMG_0407.jpg I also cleaned around the anode hole, to keep it from arcing from dust. http://img.photobucket.com/albums/v3...d/IMG_0406.jpg |
#45
