Old 04-23-2012, 09:48 AM
DavGoodlin's Avatar
Motorola Minion
That is a neat set. I had a 1952 17" GE that required very little work to get going. You're lucky those tubes were bad or else the HV would have fired up before it should have. That set is built like a tank . I think GE started using PC boards in '56 or so, very un-tank like.
That two-tap transformer is also a great feature, especially since everybody is running at 120+ these days.
Old 04-23-2012, 09:52 AM
holmesuser01's Avatar
SOMETHING bad happened if the damper, horizontal output, AND vertical output are all cracked. When the getter flash goes white, it usually means that air got into the tube.
Best of luck with them. Even with the new tubes, I wouldn't try running it without new capacitors.
Old 04-23-2012, 09:59 AM
tvcollector's Avatar
The glass on one of them is broken.. Looks like it was something more physical..
Old 04-23-2012, 12:28 PM
That set uses dip soldering. Check the board in the HV compartment. I saw a few that were arc damaged.
PS, the tubes mentioned in an earlier post are different variations of the same tube. The GTA or GTB, being the latest version.
Old 04-23-2012, 04:31 PM
stromberg6's Avatar
Smile
Looks like a "DeLuxe" chassis, and I really like the way the tube connections are brought to the top of the chassis for ease of voltage checks, etc. I've been looking at some GE schematics lately, and have found an appreciation of some of their circuit designs, and chassis layouts. I have only two Portacolors, and a small 11 inch B/W "Personal Portable" that needs a CRT. Think I'll look for an older GE to "play" with.
Happy for your find !! best of luck with it !
stromberg6
Old 04-25-2012, 10:02 AM
Replaced the horizontal out and the damper tube, got a raster now, a nice horizontal line, until my vertical out tube arrives.. Looks like this thing is going to run without any maintenance..
Old 04-25-2012, 04:29 PM
Dont run it with that line. You can easily burn a line in the phosphors. If you insist on running it, and I would, turn the brightness way down.
Old 04-25-2012, 08:15 PM
earlyfilm's Avatar
Eternal Member
Originally Posted by tvcollector View Post
...The guy said two months ago before he moved into the new house, it had a picture......
...the Hor out, Damp and the Ver out are completely bad with white blown mark on the tubes.....
In your pictures, I can see a RMA banded Sprague on the width control. Those babies have not been made for 50 years and I can guarantee any surviving ones will be leaking.
I'd personally suggest you pull the chassis and check caps for leakage, as something roasted those tubes and you don't want to roast your new ones. My first suspect would be that the grid coupling capacitor to the vertical output is leaking and cause the output tube to pull too much current and that took out the damper and horiz output.
If any tube plates - rectifier, horiz output or vertical output, start to glow red, kill the power immediately and find out why.
Jas.
Old 04-30-2012, 10:49 AM
DavGoodlin's Avatar
Motorola Minion
Ge 1954
I just had a GE 21C243 "delivered"
The CRT is a Sylvania 21ZP4 that tests pretty weak.
TVcollector, your chassis looks similar to mine.
Once I get it safe to power up, I will post in a new thread.
Attachment 174190Attachment 174191
Old 04-30-2012, 11:02 AM
Is that the model with the coffee can HV enclosure?
Old 04-30-2012, 01:37 PM
I grew up with a GE 21" LowBoy style set with a coffee can HV cage! When I was 3-4 years old, I would stand behind the TV and look through the holes in the back and watch them work. I also developed a liking for the smell of tube electronics making heat.
I have pictures of my set in the family album. I'll see about scanning them.
Old 05-07-2012, 04:52 PM
I'm anxious to see yours.. Looks like a console version..
