Old 03-31-2012, 11:25 PM
If you get the schematic, you can look up the values rather than guess or try to read them off the old caps.
The article at http://antiqueradio.org/recap.htm has a section on identifying capacitor values, including this chart:
I believe brown-green-yellow would be .15 mfd. That would be a reasonable value for that type of capacitor. As noted in the article, certain kinds of caps usually have values in a certain range. 15 mfd would be reasonable for an electrolytic, but not a bumblebee (paper) cap.
Wiring eight electrolytics in parallel sounds ugly, although it might work. Is it really that much cheaper to use eight caps in place of one?
Phil Nelson
