  #35
Old 03-31-2012, 07:28 PM
charokeeroad's Avatar
charokeeroad charokeeroad is offline
John Q
Hi Chris, I was wondering about about how I should test the resistors. As I recall from my service days working on Hawk Missile radar at least one leg of the resistor needed to be removed to get an accurate reading. I think you've got it right, if the resistor being tested is one of highest valuse then it would be possible to get a reading on it without removing one leg. As one goes down the value scale probably some other resistors would begin to add values to the reading. If one of then high value resistors did test high the at that point it would be worth while to pull one leg and test it again.
