Old 03-22-2012, 02:04 PM
Originally Posted by ctc17 View Post
The television apparatus is so very fine. I wish I could shrink himself provides for very small, and to live in the set!
Misa nota undersatnin' whata yousa sayin'....Yousa's grammer a bit funny.
Old 03-22-2012, 03:27 PM
put it back in and now the too much green (have the tint fully CW, not sure what happened. Anyway its getting better. I am sure the key is getting those balance pots set correctly (not the CRT bias pots, but the trimmers on the main board that are part of the R-Y and B-Y decoding. I really don't like taking it apart again, but seem like I may have to just to get at the adjustments. Oh and the darn screen and drive pot shafts are sloted, but part of the slot is broken so its nearly impossible to adj those once the back is on.
Old 03-23-2012, 06:59 PM
Tom S's Avatar
Tom S Tom S is offline
I've got a 1966 Porta Color model M213CWD that was owned by a priest. Low hours on it and real clean. Used to sell those sets in the later models. Also have a 1977 but it's not called a Porta Color. Nice sets.
Old 04-15-2012, 03:47 PM
got the porta color on the bench again, decided to take another stab at it after seeing the CTC-4 over in the early color and hear oldhyro talk about a misaligned quadrature coil. The CTC-4 looked a LOT like my porta color as far as color demodulation. I put the vectorscope on it and it was UGLY no circle at all just a line. so I tried tweeking the bottom coil, could increase and decrease the line but no circle. Then I switched to the top coil, BINGO circle opens up and I can see the color fingers, wow what a difference and it was only a minor tweak. Anyway the all the colors are showing up on the gated color bars now, a HUGE improvement. I need to refine my technique on using the vectorscope but is sure did the trick on the porta color.
Old 04-15-2012, 06:52 PM
watching MASH even those weak greens come if fine with correct flesh tones. What a difference!! looking forward to Columbo tonight
Old 04-15-2012, 09:01 PM
for you early porta color owners the coil that fixed everything was A17 on the sams also known as L22 the top coil.
Old 04-16-2012, 09:47 PM
some pics after the tweak of the coil on the chroma before the green was non existent
Old 04-16-2012, 09:48 PM
and a few more
