Old 02-03-2012, 10:20 PM
lnx64's Avatar
lnx64 lnx64 is offline
Grey blank screen
On my old Panasonic top loading VCR, when you have an RCA cable in the line in on the back, and the device off, on every TV I have used, it would be a black screen, because it was blanking (or it's supposed to be).
On my TV in the sig, I get a half grey screen and a half blanked screen.
Why isn't the entire screen blanked?
Old 02-03-2012, 11:31 PM
zenith2134's Avatar
hey, a timely thread for me, as I cleaned my connections on my '76 color tv which is the " video experiment " tv paired with an old Hitachi Ultravision VHS and JVC VHS camera... Using Belden lo-capacitance RCA cable for the composite in, and B-R brand RF cable... 91%isopropyl alcohol and sandpaper.
I was going to suggest that perhaps you've got a questionable connection in the cabling somewhere. I did. Flashing raster, mostly.
Otherwise, it's entirely possible that the tvcr reacts in a novel way instead of blanking the pix... I had a tv which did this. it was a mid-70s Sylvania console I trashpicked. It worked well but with a reduced vertical... got rid of it before I could fix it as it was among the 1st tv's I ever found. Anyway,,, a dvd recorder unit with RF output yielded a brightish, irregular raster. I manipulated the brite and conny to make it appear blanked, yet a strong signal was washed out & overloaded. Possible tuner or I.F. issue.
Old 02-03-2012, 11:50 PM
Rather than sending a true black video signal with sync, the VCR's modulator is probably transmitting a dead RF carrier on channel 3 (or 4). Then, it would just be random that the one TV does not display an all-black picture.
Old 02-04-2012, 12:15 AM
My Silvertone roundy goes to gray on no signal conditions as do most of my pre-electronic tuner sets. What you describe is likely perfectly normal for that set.
Old 02-04-2012, 12:20 AM
ctc17 ctc17 is offline
One of my ctc16s was doing that and I thought it was normal because it had a watchable picture. Turns out it had an open resistor and the 1st IF tube was not getting power. Now it has snow and a great picture
Old 02-04-2012, 12:30 AM
lnx64's Avatar
Hmm, this is what it does.. See what I mean, it's a freaky raster.
So it may be normal on these old sets? But then it could be a resistor problem? The TV picture overall, other than the golden yellows, is absolutely normal.
Old 02-04-2012, 02:50 AM
zenith2134's Avatar
um, hello again.. the freaky-raster appears to be a rolling vertical bar, is that correct? Or does it just sit like that? unlikely, i'd think.
it sure is entertaining how you once stated the 'golden yellows' were a thing of magnificence, yet here you cite them as an abnormal occurence
Old 02-04-2012, 07:37 AM
lnx64's Avatar
That black bar stays there, doesnt move.
I'm not sure which way to go with the yellows.. i hate it but like it at the same time.
Old 02-04-2012, 04:35 PM
The vert sync circuit is very good, but the vert freq most likely goes way off without a signal.... That is my guess... I have seen this before too.... And I think its also a blank signal from the rf modulator ( no sync) as mentioned above.... Loop a wire from that scope to the picture tube face and see what the vert osc does when you lose a signal.....
