Old 12-22-2011, 02:20 PM
66 motorola horiz size adjust
hi all yup its me again with a crazy question about this myserious set.would the horiz size coil have anything to do with horiz centering? the horiz coil has 2 coils and the slug is all the way at one coil and not even near the other. if this was turned by someone to much one way could this be a possible reason why the picture was a few inches short on the one side and me being the one adjusting the centering to fill the screen but now its about maxed to one end of the adjustment.
Old 12-23-2011, 07:26 PM
ctc17 ctc17 is offline
The efencffencey coil? Follow the setup instructions in the sams it tells how to set it up. You need a meter in the cathode current and shunt tube drop. That will teLl you allot ocean front property in arizona
Old 12-24-2011, 06:20 AM
the horiz size coil i am talking about, the slug being all the way to one end. it has 2 coils wrapped on the stick but the slug is not even near 1 of the coils and this cant be right.usually the slug is between both coils more or less for each one, making up the adjustment.
Old 01-28-2012, 05:09 AM
sharejutt sharejutt is offline
Banned
sidekick 2
Don't know if i should trade motorola a630 for sidekick 2?
