Old 01-08-2012, 08:53 PM
6GH8cowboy 6GH8cowboy is offline
Let there be light.
After comming to the point that its not a component in the H osc section I turned my attentions to the outout stage. As it turnes out the .002 cap (Riders c419) from the cathode of the HOT to the signal line has more to do with signal conditioning than I thought. My replacement was OPEN! I now have raster and the frequency is only slightly off. I have alighned acording to the write-up and I suspect I may have to tweak a component value in the osc, being the original values were flat values for the caps and replacement industry standard values are slightly higher or lower as provided. Has anyone found this to be the case when working with time base or osc circuits with the older flat values? H-Range c412 adjustment trimmer hasn't enough range.
Also I do not have a sweep generator (last used one 35 years ago) Is there a basic bare bones suggestion for an IF align or should I put in AV jacks being there ios no over the air stations anyway, or put up with the buzz when using a converter?
