that cap is not a discreet part, but rather built into a couplate (a part that has all the resistors and caps built into a ceramic looking package.
I would 1st try recapping the paper caps as that needs to be done anyway. Then I would check the voltage at the grid of the horz, should be neg, 30-50v, if not then either the horz is not working OR the couplate cap is leaking. Some folks have had those couplate go bad, i have only worked on a couple predicta's, they were fine. |
