As with most things, the answer is, it depends. Blowing fuses is often one of the easiest things to fix but there are some causes that are not simple. What is the make and model? If it's a simple 120V motor connected with a switch, it could be easy as long as the motor isn't bad. If it's a more sophisticated solid state circuit, it's anyone's guess.
