Hi Giulio
I'm fine thanks ![]() I know that in many circuits I cannot measure the plate of damper tube, but if you look at the schematic that point is marked with a known voltage. It seemed strange, and I thought of a error. In many set for checking the EHT you must see if the booster tension is similar at the value reported in the schematic (like my Blaupunkt CTV200). Enrico tell me about the 6W4 and I had thought to keep the 6AX4 as you say, since this tube has a better insulation of the heater Thank you ![]() Marco @Enrico: in fact the screen has a good light when it's on, if the ion trap have an effect on the gun I would have problems |
