Old 11-21-2011, 11:21 PM
well while messing about with the tv I noticed the shunt tube seemed to be glowing hotter than normal (and the FLY was getting quite hot as well even though the HOT current seemed right a 185ma) I need to check the V drop across the shunt cathode resistor before doing anything else. The voltage regulation seems fine, able to dial in right at 23kv, but I did not check that shunt tube current so will do that before I do any more testing on the pairing issue. I did try several 6Gf7's much to my surprise the pic vert and lin remained pretty constant, as did the line pairing issue. It seemed like one tube did a little better but its not right. if I take it to the edge I can get rid of it, so I know there is room for improvement. My scope lead took a dump so I will have to fix that and go in search of horz rate noise.
