The CTC97 is a very nice set. I ran mine into the ground. Had the two button ultrasonic remote control. It needed filter caps but otherwise very strong performer. It eventually developed a bad delay line in the color circuitry and I couldn't find one that matched up correctly.
I like how such a late set still uses an octal plug and socket to connect the yoke to the chassis. Even when this tv was made it was already a 40+ year old connector.
Seeing the set discussed here reminded me there's an XL-100, don't know the model, knob-tuned set in the Antique Depot in Annville PA. (no connection.) Don't know the functional condition of it but they are asking $55 but it's been sitting there a LONG time. Cellphone photos I took today.
Probably a CTC71 delta gun set from around '74. Those upright chassis sets are the best sets that RCA made and they produce an amazing picture when working right.
I have some Mural TV sets which are just like the last ones shown here. These always seem to have good CRT's. I have seen more weak CRT's with the early 80's RCA inline sets like the first set mentioned here.
Flybacks, 18 ohm resistor for a vertical problem and sound chip would be common problems for this chassis.
julian |
i have one of those 19 inch xl100s.mine is as plain as it gets.no afc or acm controls,no woodgrain,etc.the picture is amazing!was given to me as a non working set.plugged and played.since no remote,they didnt know how to turn it on.i will post pics later.those upright xl100s were tremendous sets and although we all preferred the zeniths and sylvanias back then,i have found a new appreciation for rca.my 19 and 25 inch xl100s produce as good a picture as i ve seen.
Have you tried your XL-100 TVs on digital cable? I think this type of cable service is far superior to the older analog systems; better signal quality, more channels and so on. I don't know what is in the Columbus area as far as cable TV service goes, but I think the area must have at least one all-digital cable system.
i have my xl100 25 inch hooked up to direct tv.the picture is amazing.the 19 inch is on a digital converter in the garage.it is just as good.reds that are red instead of orange.plain set that really delivers a sharp picture.convergence is nearly perfect and all i had to do was adjust guns.contrast is at minimum and still nice and bright.
very nice. I get a lot of comments on my old vintage set, people are shocked at how good they look. That XL100 looks nice.
I had an RCA set that looked a lot like that, CTC62 IIRC. It used plug in modules in a vertical chassis. The CRT went dead and we tossed it.
Mine is a 1974 as you can see. The first one listed I believe is circa 1983.
Aren't those the sets that deguass when you turn it off? That feature always stuck me as strange.
Unfortunately, if you're mainly into solid-state chassis sets any newer than the early Zenith flat chassis sets, you'll be relegated to the sidelines here. Last edited by Jon A.; 07-06-2013 at 05:41 PM. |
