hmmm looking closer that may have a solid state tuner, so even less likely to be the prob.
cleaning involved removing the knobs, removing a few screws that hold the tuner/controls (it comes out as an assembly), removing the metal cover on the tuner (prob the hardest part of the process), remmoving a few tuner strips by pushing them back so they can pop off (do 8,9,10 stay away from 3 and 4), then using some tuner cleaner on a q tip wipe the fingers that run on the strip contacts, use more q tips to clean the actual contacts, put it all back together, and replace the cover (again the hardest part). while its out examine closely the ant balun for any hints of burned wiring, check with a meter for continuity. The Most important part of working on any old set is to not force things, (like screws and plastic parts). Ham hands will def do more damage than a light touch. Those plastic tuner strips have small coils on them, that's why I recommend only removing those channels that are not used for gaining access to the take off fingers. if its a snowy weak pic that can be momentary fixed by careful movements of the tuner (not the fine tuning but the actual channel changing knob help partially between channels) then its no doubt just cleaning required. I agree with the other poster, he prob does not want to work on it. These old sets are somewhat labor intensive, that and the fragile nature of hard to get parts would make most folks want to steer clear. |
