What does it do exactly? Takes the tape and won't do anything else? If so, it might be in child-lock mode. I had a few JVCs come in like that, had inadvertently been locked. I recall that holding down the Power button on the remote for 4 or 5 seconds takes it out of Child Lock. |
And thanks for the advice on the Canon - I will be ordering a kit this week.
AUdubon5425 Youtube Channel |
Not good. Likely one of the reel sensors has failed.
I'm going to try cleaning them and see what happens.
What it sounds like it's doing is the tape slack take-up routine, it has to sense the supply reel turn a bit after load to sense no slack condition, but never senses the supply reel turns, so it just shuts down.
The sensors I am talking about (PC3001, 3002) are soldered to the main board, plastic, stick up, and have a phototransistor and LED arrangement that gets interrupted when the reels turn. Part number is GP3S123 (I own a JVC with the same mechanism so I have some service info.) |
Tape still threaded means the idler tire has a crack or a slippage. Check it.
Just replaced the idler tyre on one of my old D-deck National (Panasonic) units after a failure to record on Wednesday night, took all of 4 minutes, most of which was spent looking for the little split washer that flew away
Yep. JVC = gear drive.
