Ha. Did you get any of those hybrid Sylvanias with the 2-watt collector load resistors on the two demod transistors? The resistors were carbon comp, and ran pretty hot to begin with. Over time their phenolic casing would carbonize, creating a low resistance shunt that would run hotter and hotter till one of the transistors would pop and the other was about ready to pop. We replaced each resistor with two 2-watters in series, doubling the wattage rating (and of course replaced both transistors).
Sorry for the long delay in replying to you...
I rarely got a hybrid Sylvania set, but one that I did get to keep, was a 19" with no color. The B/W image was perfect, though. I never got into it enough to fix it. Eventually used the CRT in another set. I never saw any hint of color in anything we viewed on this set. Too bad, as it was a nice looking set. |
That's exactly the symptom you'd get if both demod transistors were popped. If only one was popped (the usual condition), you'd get really weird color with half the chroma information missing.
