Old 10-07-2011, 10:05 AM
Mr Hoover's Avatar
Mr Hoover Mr Hoover is offline
The drive control alters the width a little bit I found.
Some sets have extra small value HV caps fitted across the horizontal scan coil wires where they plug into the board,they alter the width...
I think you can see why they dumped the model quickly and went onto the
the little 5" set.
While you're measuring volts I had problems with low volts for the video amplifier supply which is rectified from the horizontal op stage,changing the diode for a modern type fixed it.
The diode is near the transformer at the top of the board,you can just about get to it to measure with the board in place I think,or check on the video amp which is on the middle board near the top.
Hugh
